API Query Profile: problem when using "/" in header parameter
I'm calling an API where I need to specify the header parameter:
Content-type: application/json
When doing so I get the error message: "Invalid value: parameter <Content-Type> contains a URI reserved character ("/" or "?")".
Is there any way to get around this? I tried using the API Extract Profile instead, which allowed "/".
Hi @OJ168502​,
Can you confirm which version of Matillion ETL you are using? I believe that problem has been fixed in v1.54 and onwards...
Best regards,
Ian
Matillion ETL: Version: 1.53.8
Thanks for your answer though
Ah, OK thanks for confirming :-(
An update should get you past it though, when you get a chance.
Ian
