Can I execute a SP in MSSQL
I thought the Database Query component can run a query like this:
exec schm.st_proc param1 param2
However, when I did the sample run, I get an error message:
Incorrect syntax near the keyword 'EXEC'.
Is it really impossible to do this?
I would appreciate it very much if someone can give me a hint.
I found an example:
SELECT * FROM OPENROWSET('SQLOLEDB', 'Trusted_Connection=Yes; Server=(local); Database=MyDatabase', 'EXEC abc.st_proc param1 param2')
"Ad Hoc Distributed Queries" must be allowed by the database. I will need to work with SQL DBA to get the permissions before I can actually try it.
Hello
You can try below steps-
Ensure that the query is correctly formatted for your MSSQL environment.
Sometimes, using CALL instead of EXEC can work. You might try:
CALL schm.st_proc param1, param2;
Also, make sure your parameters are correctly defined and enclosed in the right format, depending on your procedure's requirements.
Hope it helps !
Thank you😊
