Can we get output in XML format using matillion
Though I haven't implemented it earlier I found below discussions on similar requirement:
  1. https://metlcommunity.matillion.com/s/question/0D54G00007MfOoHSAV/load-xml-file-to-snowflake-using-matiliion
  2. https://metlcommunity.matillion.com/s/question/0D54G00007XAVFLSA5/unload-data-from-a-table-to-a-file-in-xml-format
For python route explained in (2) you can check: https://docs.python.org/3/library/xml.etree.elementtree.html
