Dynamics 365 Scopes
I need to create a custom Dynamics 365 API connector.
I can't find the list of scopes that Matillion's native Dynamics 365 connector is using when I generate the OAuth.
Is there documentation on what initial scopes are used by Matillion when I create an OAuth using the native Dynamics 365 connector?
Cheers
Actually turns out I don't need to assign scopes. I was logged in as an "admin" user so that alone seems to give me enough "scope" to pull everything I need from a custom connector.
