Failure transition not followed despite a failure component
Hi Team,
I built a data pipeline in DPC where i am using a grid iterator that is set to concurrent and calls the child pipeline for each iterator using run ORCH. now that run ORCH failure is connected to a SQL script component that calls a procedure in case the pipeline fails. My understanding is even if one iteration fails that failure is returned to the main pipeline nand the failure sql script should be called which is not happening, the iterations are failing its drectly going to end success and skipping the failure sql script call, this is the execution ID:Pipeline status-FAILED
Pipeline execution ID==019d53bf-c3c5-7f8c-82a3-5950c4fd5a69
Hello @pmathur
Thanks for your post, let me take this away and look into it for you.
Hello @pmathur
Thank you for your patience whilst I looked into this. The team will need quite a bit more information from you. The quickest and easiest option at this moment would be to raise a case regarding this with our support team.
Please let me know if you need any assistance with this, if not please do keep me posted on how you get on.
