Git not recognizing remote branch deleted
After deleting a remote branch in Github, the Git tree navigator in Matillion locally still displays like a remote branch exists. Is anyone else experiencing this and/or know how to have it fully remote the reference to the remote branch?
Hi @Singularity
I hope you are well, I have had a look at this with a colleague. It sounds like something that our support team will need to take a closer look at.
Please raise a support case via the support portal or support@matillion.com
Thanks for commenting. I received feedback earlier on this; the resolution was to select "Remove old refs" when fetching an update from the remote branch. There were still a few instances where Matillion is retaining old branch refs from remote that no longer exist in the remote - the guidance was that this may be because of a record on the database from a prior server we migrated from. To remove those, I would need to log-in to the server back-end and remove the references.
