Google Analytics 4 : Advanced query does not work properly/consistent
So, I have the query for combining 3 datamodels as following :
SELECT t.Date, t.Hour, t.DeviceCategory, t.Browser
--, a.SessionSource, a.SessionMedium, a.Sessions
,t.TotalUsers
--,CAST(NULL as DECIMAL) as PercentNewSessions
, a.NewUsers, CAST(NULL as DECIMAL) as BounceRate
, CASE WHEN a.Sessions=0 THEN 0 else e.ScreenPageViews/a.Sessions END as PageviewsPerSession
,e.userEngagementDuration, CAST(NULL as DECIMAL) as GoalConversionRateAll
FROM Tech t
, Engagement e
,Acquisitions a
WHERE t.Date=e.Date and t.Hour=e.Hour
AND t.Date=a.Date and t.Hour=a.Hour
The above query works fine, but when I uncomment lines 2 and 4, there is no data returned.
It shouldn't work as the above, since Im just adding/removing columns from select list. This behavior is buggy
Hi @Lion9876543211618923990717
Does this help https://support.matillion.com/s/article/UnabletoaddanewdatasourcewhenusingtheGoogleAnalyticscomponent ?
Chika
That works, thank you. Please fix it in next version !
