Hi all!
It would be great to be able to use keyboard shortcuts to run a job rather than right-click > Run.
Hi all!
Common windows keyboard shortcuts can be used inside Matillion ETL.
A reminder of these can be found by right-clicking the canvas and consulting the menu (shown below). CTRL + C - (Copy) : Copy a selected component, job or text to be pasted elsewhere. CTRL + V - (Paste) : Paste whatever has been last stored through Copy or Cut.
CTRL + Z - (Undo) : Revert the job layout to the state before its latest change. Can done multiple times to revert back to any state within the current session.
Note this only applies to the canvas and will not undo changes such as job deletions.
CTRL Y - (Redo) : Reapplies the last undone change. Thus,can only be used after Undo. Can be used multiple times until the latest version is reached.
CTRL A - (Select All) : Instantly selects all components, notes and links on the Canvas.
CTRL+RETURN (Run Job/Close Dialog) : If on the canvas, this will attempt to run the current job. If a dialog box is open, this will confirm and close the box.
CTRL+SHIFT+R: Open a searchable dialog listing all jobs in the current project.
CTRL+SHIFT+T: Open the Search Tab panel.
I hope that helps :)
