Hi We are using Datastage as ETL tool and trying to see if Mattilion can help us in migrating jobs from datastage? The target db will be oracle for us
Hi We are using Datastage as ETL tool and trying to see if Mattilion can help us in migrating jobs from datastage? The target db will be oracle for us.
Hello casper_28
The simple answer is yes, Matillion can help.
I imagine you would load data from Datastage into an IDM Db2 database, is that correct? Or do you load it somewhere else?
Basically, if you load it into IBM Db2 or any other supported database / data warehouse, Matillion ETL will be able to migrate it from there to an Oracle database using a combination of the Database Query connector and Oracle Output connector.
Regards
Ben
Matillion Product Team
Thanks Ben
would load to oracle. We have around 5000 files that we load daily to oracle through database and everything is on premises.
Can matellion help us in getting this .. we are thinking to replace the etl tool but rest remains same as input and output cannot be touched.
Questions
1. Can matellion read data from in house servers. ?
2. And write to in house oracle dB?
3. Or these files have to sent to cloud for faster processing ?
Hello Casper
The answer to your questions:
  1. Yes, Matillion can read data from in-house / on-premise servers.
  2. Yes, Matillion can also write to in-house / on-premise servers.
  3. In our pattern, files will be staged in a storage bucket (temporarily) and loaded into a Cloud Data Warehouse for orchestration and transformation.
Do you have any questions or requirements beyond this that I can help with?
Regards
Ben Smiles
Thanks Ben for the quick response.
Is number 3 a mandatory one ? I am new to mayltellion so apologies. Can you elaborate or point me to some documentation that can help me better understand as well.
Thanks
Hello casper_28
Our stage and load pattern is somewhat mandatory in that a cloud data warehouse is required to use Matillion.
Files can be staged and stored in a storage bucket, but a data warehouse is used for orchestration and transformation.
Please refer to the following for details on our connectors and load pattern:
https://docs.matillion.com/metl/docs/2701143
https://docs.matillion.com/metl/docs/9631728
https://docs.matillion.com/metl/docs/1975061
Regards
Ben Smiles
