I would like to send an api message to Fivetran to suspend a connector replication from a DPC orchestration job just before we do transformations in Matillion DPC. They (FIvetran) have a 'patch' API call that I was able to trigger using Postman (curl) to cause Fivetran to pause a connector. I would like to do the same thing from Matillion DPC (full SaaS).
I've been thinking about this over the weekend, as I appreciate the idea will take some time to come to fruition. If this is Snowflake, you can likely do what you're trying using the Python Pushdown component and a bit of Python to make the API call.
As John said the only way to do this to code something in Python. You can send WebHook Posts from Matillion but not generic API request. You can still use a Custom Connector if you API requires a GET or POST message but not if it requires a PUT message or any other.
To code the Python you can use AI. I found it good enough, although you quite often need to doble check and correct the code.
In Snowflake you would need to create an "Integration". Matillion has a doc on that: https://docs.matillion.com/data-productivity-cloud/designer/docs/python-pushdown/#snowflake-configuration
Basically Snowflake is completely closed to the external world so if you want to send data out (or in) you need to create a network rule to open Snowflake firewall.
I've have looked into that. We do use Snowflake but we do not have deep knowledge of using Python and/or Snowpark (which I think is required). As time permits I will investigate but going down this road may lead to more questions than it is worth at the moment. Are there any video's describing/showing how to use this component with Snowflake?
Thanks. I've had a quick look at the python pushdown but will need to review more. Not sure what you mean by an 'integration' in Snowflake. We already use a dedicated Snowflake service account for Matillion and created a network rule to allow DPC to connect. Is there another integration type that is required for Python pushdown?
Yes, you need to create a network rule to allows Snowlflake to connect to FiveTran. Then add this network rule to a Snowflake Integration and finally add that Integration to the Python Pushdown component.
You do this just once with an ACCOUNTADMIN:
CREATE OR REPLACE NETWORK RULE fivetran_access_rule
MODE = EGRESS
TYPE = HOST_PORT
VALUE_LIST = ('Here your host or IP where you need to send the API message.');
CREATE OR REPLACE EXTERNAL ACCESS INTEGRATION gkc_w3schools_access_integration
