How to check Volume?
Our matillion etl faced Out of memory issue on this month so I checked the log it has not sufficient data I need. I want to find the extract volume consumed during the Out of memory issue.
Is this can checked by any method or it should achieved by deep checking of catalina log. Is it please help me to check it.
Regards,
Hari
Hello @HariRamK
Thanks for your post. I would recommend raising a support case to look into that, the team can look into it for you.
They would need the heap dump and log files, this is if you have heap dumps configured there is some information on this here.
Keep me posted on how you get on.
