I am trying to edit the shared job's reference job. Highlighted part of the picture. Any support/insight on the below is greatly appreciated.
Prajwal
If you are using a "Read-only" Shared job, you can unpack the Shared job, edit the reference job, rename and pack it as your custom Shared job.
Thank you @AnudeepK . After a lot of frustrating trial and error, I was able to figure this out quiet some time ago. Appreciate your response.
