How to execute redshift function "ANALYZE COMPRESSION"
i try to execute the redshift function "ANALYZE COMPRESSION" to receive the best encoding for columns in a table. I used in an orchestration job the SQL script component to execute this function but i received no result table. I also try to execute this in a transformation job with a sql component, but this end with a syntax error message.
With best regards,
Dirk
Hai @DirkZ​ can you please try analyze tables component
0694G00000LX1GmQAL_0D74G000008Q7LySAK
Thanks
Subash
the "Analyze tables" component only update statistical metadata, but not allow to execute the command "ANALYZE COMPRESSION" to receive a result regarding best column encoding for a specific table.
Hai @DirkZ
Apologize i also faced same error😂
