How to export an orchestration and transformation pipeline from Matillion?
You can click on both holding ctrl on your keyboard and clicking with the right button to get this:
After that, click on Export, that will open up another screen for you to manage what you want to export together with the jobs you selected.
I hope that help you!
I am not seeing this option. Here's what I am looking at:
Any thoughts?
Ahhh you're using the DPC, not Matillion ETL. That's why.
Ok, DPC is very powerful but still new, so we are missing some features there yet. I believe that export option was not included yet, but I'm pretty sure that is on the roadmap to be included soon.
Thank you for sharing your support on this @marcusblackhill​ as you mentioned @archil.bhaiya​ is using the Matillion Data Productivity Cloud, I have tagged your discussion so it goes to the correct area of the forums for you, as Marcus said this feature is on the roadmap and will be delivered soon, I will be back in contact when it is available to let you know.
If you need anything else please let me know, we hope you are enjoying using the Matillion Data Productivity Cloud and of course welcome to the Matillion Community!
Hi Joe,
I am facing an error while I am trying to run a transformation pipeline and attached the screenshot below.
Can you please guide on how to fix it?
[cid:image001.png@01D9EBD8.199C3070]
Regards,
Archil
Hi @archil.bhaiya​
That screenshot seems to have not worked, can you resend, please?
Thanks Joe
