File names are same, But sheet names are different
You could use one of the iterator components to iterate over the different sheet names. I think this also requires a mapping "file (with path)" -> "sheet name". You have provided very little information on your problem so I can't go more in detail. If you require more help, please post more details on your setting.
Could you please brief out how to load multiple sheets of an excel in matillion .
Example - Excel File name - EXCELLOAD
Sheet names - A,B,C ....and so on
Quick description:
- Create a job variable of type VARCHAR and name "sheet"
- Create a fixed iterator and add values A, B, C (your sheet names)
- Configure the iterator to use your previously created variable
- Configure the Excel Component as usual
- In the Excel Component, instead of typing the sheet name, use the variable ${sheet}
