HTTP protocol error. 401. - when running <API QUERY> matillion component
Hello. I am trying to use <API QUERY> Matillion component.
I use the settings like: 1) Profile field: "Matillion API" 2) Data Source field: "Run Historical Details"  3) Other required fields are set as well.
Result of running this component is: HTTP protocol error. 401.
When I choose Profile field: "Sample", I am able to load the data in the table.
Please let me know what could be a problem?
Hi AGosp,
A 401 error means unauthorized, so you mabye have not put a username and password?
On my system I have to remember to set
  • Authentication Method = User/Password (it defaults to 'Other')
  • Username = A Matillion user which has been granted API privilege (more info in this doc)
  • Password = the user's password
For me sample never works without the above.
BR
Thank you @deBaris​
I set the username and password and the issue was solved!
Best Regards, Alex
