Hubspot Owners v3
Thanks @roy.taylor
Our support team are going to contact you relating to this as they want to take a closer look and help you with this.
Please keep us posted on how you get on.
I will let you know. I’m in the midst of an upgrade to a new instance of Matillion (after our discussion with y’all (Kevin K.) last week. Apparently our account has been tracked under a different name.
I was trying to do the oauth with the new instance, to see if things were still not quite working, but I can’t generate new ouath tokens with only the IP address(?). Apparently hubspot doesn’t like that as a redirect destination. Once I get everything set up, we will re-point the DNS record and I’ll see what kind of behavior we can see.
No worries @roy.taylor
Keep me posted on how you get on, we are here if you need anything else.
So I’m trying this with a “Private App” as well…and everything EXCEPT the Owners is avialable.
When I add in the “Connection Options”, I can’t get the component to validate.
And I don’t even get the dropdown options.
And again, getting clean calls on the back end.
This is now on Matillion ETL 1.77.9
Thanks for sharing, @roy.taylor
Our support team will definitely need to take a closer look at this. Can you confirm if they have contacted you yet?
Thanks Joe
I am not seeing one specifically in my email. I will take a closer look and mention this to our dedicated tech rep (who I’ve since met with after this thread started).
Thanks all, appreciate the help.
You are welcome @roy.taylor
Do let me know if I can help with anything else and again welcome to the Matillion Community :slight_smile:
