Hi all,
this is a bit of urgent request.
I'm trying to integrate HubSpot Contact API in Matillion, I can sample the API query component, but the pagination is surely not successful.
I get records only from first page. I have tried almost everything in rsd file, not sure to to increment the page number here.
Can anyone help with this please?
This is the code:
<api:script xmlns:api="http://apiscript.com/ns?v1" xmlns:xs="http://www.w3.org/2001/XMLSchema">
<!-- See Column Definitions to specify column behavior and use XPaths to extract column values from JSON. -->
<api:info title="a" desc="Generated schema file." xmlns:other="http://apiscript.com/ns?v1">
<!-- You can modify the name, type, and column size here. -->
<attr name="archived" xs:type="boolean" readonly="false" other:xPath="archived" />
<attr name="createdAt" xs:type="datetime" readonly="false" other:xPath="createdAt" />
<attr name="id" xs:type="string" readonly="false" other:xPath="id" />
<attr name="properties_createdate" xs:type="datetime" readonly="false" other:xPath="properties/createdate" />
<attr name="properties_email" xs:type="string" readonly="false" other:xPath="properties/email" />
<attr name="properties_firstname" xs:type="string" readonly="false" other:xPath="properties/firstname" />
<attr name="properties_hs_object_id" xs:type="string" readonly="false" other:xPath="properties/hs_object_id" />
<attr name="properties_lastmodifieddate" xs:type="datetime" readonly="false" other:xPath="properties/lastmodifieddate" />
<attr name="properties_lastname" xs:type="string" readonly="false" other:xPath="properties/lastname" />
<attr name="updatedAt" xs:type="datetime" readonly="false" other:xPath="updatedAt" />
<input name="rows@next" desc="Identifier for the next page of results. Do not set this value manually." />
<input name="totalCount" desc="Records total count" />
</api:info>
<api:set attr="BackwardsCompatibilityMode" value="true" />
<api:set attr="EnablePaging" value="TRUE" />
<api:set attr="elementmappath#" value="/paging/next" />
<api:set attr="elementmapname#" value="totalCount" />
<api:set attr="limit" value="100" />
<api:check attr="_input.rows@next">
<api:set attr="uri" value="https://api.hubapi.com/crm/v3/objects/contacts/search?offset=[_input.rows@next]&limit=[limit]" /> -- I replaced limit with 10, but did not work
<api:else>
<api:set attr="_input.rows@next" value="0" />
</api:else>
</api:check>
<!-- Column XPaths are relative to a RepeatElement that splits the JSON into rows. -->
<api:set attr="RepeatElement" value="/results" />
<!-- Uri parameters set up -->
<api:set attr="paramname#1" value="propertyName" />
<api:set attr="paramvalue#1" value="[_connection.propertyName]" />
<api:set attr="paramname#2" value="operator" />
<api:set attr="paramvalue#2" value="[_connection.operator]" />
<api:set attr="paramname#3" value="value" />
<api:set attr="paramvalue#3" value="[_connection.value]" />
<!-- The GET method corresponds to SELECT. Here you can override the default processing of the SELECT statement. The results of processing are pushed to the schema's output. See SELECT Execution for more information. -->
<api:script method="GET">
<api:set attr="method" value="POST"/> <!-- HTTP request type -->
<api:set attr="data">
"filters": \[
"propertyName": "",
"operator": "EQ",
"value": true
</api:set>
<api:set attr="ContentType" value="application/json" />
<api:set attr="nextOffset" value="[_input.rows@next | add([limit])]" /> -- I replaced limit with 10, but did not work
<api:check attr="totalCount">
<api:check value="[totalCount | isgreater([nextOffset])]">
<api:set attr="rows@next" value="[nextOffset]" />
</api:check>
</api:check>
<api:call op="jsonproviderGet">
<api:push/>
</api:call>
</api:script>
</api:script>
