as soon as i'm trying to install this error is popping up
File "/tmp/interpreter-input-1527884b-2589-44a3-bbe2-e5d0c001c058.tmp", line 1
pip install google-ads
SyntaxError: invalid syntax
Script failed with status: 1
Can you share your full code sample? Which component did you use to execute the code?
are there Matillion docs that explain where to put the python packages?
