is there a way to convert a Matillion trn job into plain SQL? so we could see the job like a stored proc
Hi @steve.inglis
If the trn job has an output table, in the SQL tab of the output table properties, there is a check box on the bottom left called 'Expand References' and that provides the full sql for the trn job.
Moreover, it would be useful to know if there is a wider ask here. Are you interested in using less of the product, or are there any pain points you're trying to address by going down this route? Moving to a stored-procedure would mean:
- you would lose the ability to easily test/troubleshoot the job logic
- our updates may include improved SQL being emitted in a later release which you may miss out on
Hope this helps, Steve!
Chika
Thank you, my intension is to be able to track full data lineage - I was hoping getting the the sql would give us the oppountity to do this easier
Hi Steve, Just checking if you'd seen the Matillion Metadata API can provide lineage information: https://documentation.matillion.com/docs/9907241#lineage-log-api-endpoints
Hi @Phil_BMatillionSalesEngineer — thanks for jumping in here and recommending a doc!
Thanks - I've just seen a short video on Matillion to Collibra connection. This is very interesting. I'd love to know more about this
There's a page here on the setup (and possibly the same video you already saw 😊 ): https://documentation.matillion.com/docs/collibra-integration
Thank you
