Hi all,
I have 4 data in a single row with comma(,) as delimiter ex:(9159664455,582244555,4785154546,5565566546),here I want to bring the 4 data in 4 different columns.
So,is there any idea or logic to solve this?.
Hi all,
use the SPLIT_PART function in Matillion:
SPLIT_PART("C1", ',', 1)
SPLIT_PART("C1", ',', 2)
Where C1 is the input string
', ' is the delimiter
1 is the n-th occurence
When there are always 4 values this, added with 2 additional lines for 3 and 4 will do and will give you columns. See the added json for import in Matillion
@HariRamK In matillion we have a component named as Split Field which helps you to achieve your output.
Yeah, I think this one will help me more. Thanks for your time and help.
Ok I got it I will try it
