Trying to provide environment variable in "Variable to iterate" attribute of loop iterator component.
The variable is of type numeric and value is 5
still the validation complains with error - "Unrecognized Value"
Hi ankit,
You have a dropdown menu with available variables. If it is not there the variable you want to iterate might not be in your environment or job variables present.
@twan.nijhuis : The variable is available in the list. Its when I pick up - the validation error props up. The variable type is numeric as advised in documentation
