Marketo API Lead Object Change Data Capture Audit Field UpdatedAt Not Working in Filter Condition using via Matillion to Extract in Snowflake Instance
Marketo API Lead Object Change Data Capture Audit Field UpdatedAt Not Working in Filter Condition. Using filter on CreatedAt seems working fine and Delta capture is feasible but not with UpdatedAt which is most fault resilient
Having this error “1035, Unsupported filter type for target subscription” for UpdatedAt column used for delta extraction.
Any help is appreciated
