Occasionally we are seeing scheduled Matillion jobs that fail but the Task Info does not show the error.
Please see below:
The job ran again successfully the next iteration. Is this an bug or … ?
We are running Version: 1.61.6 (build a392342-2471)
Thanks
Hi, do you use explicit "End Success" or "End Fail" Components in that job? I think that sometimes leads to confusion in the task history.
True. It is a good practice to use exclusive End Success or end Failure components to your Orchestration job. Sometimes the failures will not be reported to Orchestration, especially when you are connecting the next components using Unconditional connectors.
