Matillion Exchange - Community created Shared Jobs removed?
I was just searching the Matillion Exchange and noticed that a lot of the older shared jobs no longer appear.
I basically went through the entire list and only Matillion created shared jobs showed up for me.
Did something happen to remove community created shared jobs or are they in another location?
Cheers!
Hi @SB699925​
We are making some changes to the exchange and some items have moved and others have been migrated.
Is there a specific item you require?
I can liaise with our team and look into it for you.
HI Joe,
Apologies for the late response. I wasn't looking for any job in particular just searching the shared jobs. I had published a couple of shared jobs to the exchange myself and noticed that I couldn't find them anymore. :D
Do you know if you plan to restore community created shared jobs in the future or should we go through publishing those again? Just curious.
Cheers,
Steve
Hello @SB699925​
I will connect you with my colleague @johnathan.law​ he will be able to give you further information don't his subject for you.
Thanks, @JoeCommunityManager​, and hey, @SB699925​. It's a pleasure to make your acquaintance!
As Joe mentioned in his earlier message, we've been making changes to the exchange as we continue to work on the Data Productivity Cloud and have published items (so far) that have been actively downloaded and contributed to recently. We're working on how to make this even better in the future, as we've now implemented import/export within the Data Productivity Cloud and are looking to continue to improve! We're just at the start of the journey! In the meantime, we can retrieve and share previously published jobs if people are looking for anything that has been shared previously.
We're keen to make sure that users don't have to go through the additional effort to bring jobs that have been previously published, but we are also eager to try to ensure that the exchange isn't prohibitively heavy from the get-go. If you have any ideas. or would like to schedule a chat with me, feel free to do so here.
Johnathan
