Hi Matillion Community,
I'm facing an issue while loading Timestamp objects from a MongoDB table to a Snowflake table.
In my MongoDB table, I have a field nammed T with type Timestamp. Here's an example : Timestamp(1685434558, 15). It represents Tuesday 30 May 2023 08:15:58 with an ordinal increment of 15.
I load this MongoDB table in a Snowflake table with a MongoDB Query Component by adding this simple SQL query : SELECT document(*) FROM table; The schema of the Snowflake is the following :
CREATE OR REPLACE TABLE tableName (
JSON VARIANT
The output of the field T is the following in the VARIANT Snowflake object :
"$timestamp": {
"i": 1807392968,
"t": 392
My question is the following : what are i and t and how can I convert the Snowflake object to get my 1685434558 seconds Timestamp ?
Thank you for your help,
Have a good day,
Victor
