New issues with Create Table component starting from April 2025 (Matillion DPC for Snowflake)
Noticed two new issues when creating a Snowflake table in Matillion DPC:
  1. There is a new version of the ”Create Table”-component. A message about it appeared in an Orchestration pipeline. Problem is that I cannot find any release note or documentation about what has changed? I saw that a Transient table type is now supported, but is there something else changed? The message: ”New version available. This component will continue to work in your existing pipelines. A new improved version is now available. Simply search for the same component, then add it into your pipelines to configure and execute.”
  2. Another new issue is that now when I use method ”Create if not exist” the log shows ”Created table” although the table already exists. Earlier it showed message ”Table already exists” or something similar. If the table already existed is an essential information, and needs to be showed properly in the logs. The logs tabs is even more concerning, since it implies that the table has been replaced (fortunately that is not the case and the data was not lost in the database), which creates confusion.
    Logs for the 2nd issue below, the component has method ”Create if not exist” and the table already exists in the database:
|Create Table|19|[2025-04-04, 13:04:35]|Creating table: "STAG_EDW"."DATASTORE”.”SUBS”|
=> Create or replace?! => |Create Table|20|[2025-04-04, 13:04:35]|Invoking external service: snowflake, create or replace table|
|Create Table|21|[2025-04-04, 13:04:35]|Creating new connection to the warehouse.|
|Create Table|22|[2025-04-04, 13:04:35]|Invoking external service: snowflake, execute action|
|Create Table|23|[2025-04-04, 13:04:35]|Finished invoking external service: snowflake, execute action in 241ms|
=> Create or replace?! => |Create Table|24|[2025-04-04, 13:04:35]|Finished invoking external service: snowflake, create or replace table in 242ms|
|Create Table|25|[2025-04-04, 13:04:36]|Created table ["STAG_EDW"."DATASTORE”.”SUBS”]|
I’m using Matillion DPC for Snowflake.
Hi @MW, a warm welcome to the community to you!
Thanks so much for posting these, let me go and find some answers for you. I’ll be back as soon as I can.
Many thanks, Claire
Hi @MW and thanks so much for your patience.
There has been a recent update to the Create Table component documentation which added new Transient table type to the Table Type parameter for Snowflake. It has also been noted in the change log now.
Thank you so much for sharing your logs, I’ve spoken to the team and I’ll be raising this as a bug on your behalf for review.
Thanks again for your patience! Claire
Hi @ClaireSeniorCommunityManager!
Do you have any updates on fixing this bug? I couldn’t find anything about it on the Matillion Roadmap.
Also, am I misremembering, or did Matillion DPC used to have this feature? I recall being able to check the logs to see whether a new table was created or skipped if it already existed.
Hi @MW
I will jump on this and get an update for you ASAP.
In the meantime, please do let me know if you need anything else.
