RDS Bulk Output throws an error. ERROR: column "KEY" named in key does not exist Position: 332
Even though the table has the column KEY, The RDS Bulk Output throws an error. If I remove this column from the primary Key parameter, The component works fine. It's so frustrating.
Hi @ksingamsetty​ , I'm sorry this wasn't spotted sooner. Is this still an issue for you? If so, I'm going to ask a really silly question now. Can you let me know if the Key column is written in lower case or upper case? Are you able to change it to the opposite at all? Let me know if you're able to try that and if it has any affect.
