SQL server connection -Login timed out
Any thoughts on why the login to sql serve connection would time out.
error from admin log file :
10-Jun-2022 17:53:15.398 WARNING [https-openssl-apr-8443-exec-9] com.matillion.bi.emerald.server.modelmanager.JobReader.getTransformationJob User [ghhghhg]
failed to retrieve the Job with ID [58664] from the Version with ID [58887] in the Project with ID [57] for the Project Group with ID [54]. Version [58887] does not contain a
Transformation Job with ID [58664].
10-Jun-2022 17:53:15.455 INFO [task-thread-15-5]
10-Jun-2022 17:53:16.914 INFO [task-thread-15-5] com.matillion.bi.emerald.server.model.util.jdbc.JDBCQueryHelper.getSchemas Making a connection to determine schemas for
[jdbc:jtds:sqlserver://x.x.x.x:5000/test]
10-Jun-2022 17:53:36.931 SEVERE [task-thread-15-5] com.matillion.bi.emerald.component.implementation.orchestration.PropertiesLoader.runSchemasLookup Error running schema lookup
