attempting to write some data from Snowflake -> RDS Aurora MYSQL
on all my RDS Query components I have JDBC options for the above.
however, for the Output it does not recognise these options and won't let me run the job (invalid parameter failure)
are you able to help?
Cheers.
ASD
2
Hi Could you please share more details? also did any of this worked earlier, have you tried disabling SSL from RDS end?
This works on the RDS Query with Aurora MySQL component with no issues (useSSL, verifyServerCert)
This does not work on RDS Bulk Output for Aurora Mysql.
the only difference is at the component level.
Also I cannot disable SSL - the error I get is very specific if I add in no JDBC options - is that it's excepting me to use SSL.
ASD
5
I think in this case checking with support team would good idea: https://support.matillion.com/s/
