I see in posgres DB of Matillion there are two tables for task history: run_history_job and task_batch_history. It seems task_batch_history is what task history feature shows on Matillion menu UI. But run_history_job makes me confused.
Also confused! On my system they seem to be at the same granularity, so it looks like there is some duplication. The id in task_batch_history is the same as the taskbatchid in run_history_job. However there are sometimes run_history_job records with no matching task_batch_history (and never the other way around).
I guess it's not safe to make any assumptions about the underlying tables becasue they change over time. The only safe way to automate the retrieval of task history data is through the published API.
