Whether I will get the Update Or not?
Hi Team,
I currently get noticed for new "Update Available" from the Matillion ETL in the Notices field. So, I followed the instructions and went to the Matillion ETL Updates, but unfortunately, in there there is no current update for my Matillion ETL. Is there any reason for this and if it helps me to update the ETL as soon as possible.
Regards,
Hari Ram K
Hi @HariRamK
I hope you are well, I am sorry to see this, I am sure we can get to the bottom of it for you, if you can, would you be able to send me your log file via private message, I can check over that for you.
Hi @HariRamK
Just an update to this, I have raised a support case on your behalf, it would be beneficial for the team to look into this alongside you.
@JoeCommunityManager​ Thanks for quick supporting.
regards,Hari
