Access Project Secret Definitions from Python Pushdown Component
Hello I am looking to use the python pushdown component to generate a JWT Bearer Token and then update a Matillion Project Secret Definition for use with a Custom REST API connector I created.
Is it possible to read/write to secret definitions defined in Matillion DPC? Is it possible to update Secrets I have created, e.g., signed JWT Bearer token, through the Python pushdown component?
Any code examples would be greatly appreciated.
Hello @bhensel
Thank you for your post and welcome to the Matillion Community!
You are unable to do this via Python Pushdown but you can use the Snowflakes Secrets instead, full documentation here.
If you have any further questions, please do not hesitate to ask.
