Is there a way to change variable values in the orchestration job? Have duration from a task, but it is in milliseconds not seconds. Tried sql script but it does not let me use a SELECT ${variable} / 1000
Hi @rka1621004583744ā, I am assuming you have a job variable with a default value that is some millisecond value but then you need to update the value to be the equivalent value in seconds. If that is correct, you can do this a couple different ways. One way would be to use a Python Script component.
The python script would look like the below. In the below example timeval is your job variable with the millisecond value.
import math:
val = int(timeval) / 1000
print(math.trunc(val))
context.updateVariable('timeval', str(val))
I hope this helps!
Hi. I'll try that. Never written python before, but might as well start learning that code language as well
