How to set variables and use it on transformation job
Hi, all.
I would like to know how to set variables and use it on transformation job.
As of orchestration job, there is Python Script component, so I can define some variable and give it to next component as a.job variables.
But as of transformation job, there is no component which can define variables like Python Script component.
What I would like to do is below.
1. Define '$​start_date' which will be the before 90 days from today, as a string and format is like '20210924'.
I could define like this on orchestration job by Python.
2. I would like to use '$​start_date' in SQL component like this.
SELECT
FROM
test
WHERE
start_date = ${start_date}
If there is something component like Python Script on transformation job, or there is some different ways, please let me know.
Thank you.
I've gotten caught up by this before. There is a solution, I think, but it isn't super-obvious...
First, in your Orchestration Job, assign values to some variables (e.g., using Python Script component as you described.)
Then, set up a Transformation Job with job variables, to be called by your Orchestration Job.
Then, in your Orchestration Job, add a "Run Transformation" component, and look at the Properties of the Run Transformation Component. See "Set Scalar Variables" and "Set Grid Variables" -- these are what you can use to pass the values of your "Orchestration Job variables" to you "Transformation Job variables."
Dear Kevin
Happy New Year and thank you for your kind advise.​
You mean, on transformation job, I need to define Job variables like 'start_date' first and write it on SQL component like '${start_date}' right??
I'm gonna try tomorrow and I'll let you know how it works.
Sincerely
Dear Kevin
Hi.
Like I wrote 2days ago, I tried to give some variables to "Run Transformation" component on orchestration job.
As a result, it was successful and this is what I wanted to do!!
Thank you for your advise and I hope it will useful for matillion user.
Thank you.
