We just upgraded to version 1.54 last week. Since that time we have two minor problems (minor for us maybe not for others). We have two Matillion servers. Both have the problems. Has anyone else seen these?
1. Cannot access or use any V1 API Endpoints. The jobs were working fine before upgrade We can use v0 just fine. The V1 gives 403 error with the message NOT LICENSED. Same error from Postman, CURL, or even inside Matillion itself.
2 While a job is running, you can expand the task log fine, but you cannot open the details pop up modal until the job is done. The little green button will not open the modal while the job is running. This is not a problem in older builds.
Anyone having similar problems? Thanks
