Matillion ETL users must upgrade to a long-term support LTS version, or patch their instances, to patch requirements concerning Hazelcast v3 before 1st April 2024.
For more information click here.
Hi Joe,
We are currently on version 1.68.12 and my understanding from the update announcement is that we can in-place update to version 1.68.19 which has the ETL licence fix applied.
Is that correct?
My second question is when I run the update option in Matillion Admin, I get a $ Script timed out error like you see below:
Is there a way around this or another method to check for in-place updates on the server directly?
Steve
Hi @SB699925 , apologies for the late response. If you've gone through the document that was linked and you're still unsure, please contact our support team as they will be the best people to help you with this.
All good, thanks @ClaireSeniorCommunityManager ! We did the in-place hotfix last month which resolved our issue. I was just curious why the update from the Matillion admin menu wasn't working as expected. I think in future we are looking to go to the Cloud version.
Cheers,
Steve
