API initiated job stuck in Pending
After standing up a new matillion instance. We’re unable to run jobs that are dropped in the sqs queue, I can see the job mentioned in the Catalina log but nothing in the Tasks. If I try to trigger a job manually via API, it goes straight to “Pending”. .
Hi @major.phillips​ ,
This sounds like a candidate for a support request as it probably has ties to the inner workings of Matillion. Sorry, this isn't of much use but I am sure support could shed some light.
Hi, see this KB Article:
Schedules, API or Queue Jobs not running - schedules are not active
Please enable the schedules on a project:
0694G00000PT5AGQA1_0D74G000008hanWSAQ
This can happen after a migration when you select schedules to be disabled:
