Referring to Schedule API https://documentation.matillion.com/docs/2103629 , I see post only for update and delete but not for create.
Does this mean I need to use UI to create schedule and then retrieve information using schedule API? What is the API to check the status of schedule trigger. Currently I use Task API but I am unable to link Task with Schedule name/id
