Be delayed validation
HELP!​
When creating ETL processes, there are often too many unnecessary validations. This prevents the necessary validations from being executed, causing errors in the components. Is there a solution other than restarting the server to resolve this?
Hi @Daikichi​ which version of Matillion are you using?
Hi, @HariRamK
I use 1.75.15
Hi,@Daikichi​ we also faced the same components stuck in validation state in the Matillion 1.75 versions, we also created the issue ticket to matillion team. If you upgrade, your matillion to latest version this issue will fixed. Also read the new version release note before the upgrade.
