Hi, Can someone help me what is the best approach to connect MS Access db from Matillion and load data to Snowflake on daily basis.
thanks
C
thanks
C
Hi, have you tried components Database Query? It is for connecting on-prem databases to Snowflake and stage the files in S3. Not sure if it has an option for MS Access DB.
Anyone have any thoughts on a specific JDBC Driver for MS Access? I have not been able to find one.
This would be my first suggestion as well. You can install custom drivers for the Database Query Component. If there is a JDBC driver for MS Access available, you should be able to use it with this component.
