I'm using Data transfer to transfer a file from S3 to SFTP and S3 to network. The file in S3 has data, however when I run the job, the same file that is moved has data in S3 and there is no data in the SFTP file and no data in the network folder. It's like the file is moved/created in SFTP/Network, but data does not transfer.
Hello emoncada
I would suggest speaking to our support team regarding this issue, as there are a number of things that could cause this issue and most have to do with the setup of the source, component and target. This is not something we would be able to answer in a chat.
https://support.matillion.com/s/
Regards
Ben Smiles
Matillion Product Team
Will do, thank you!
