Disabling SSL
Hello, is it possible to disable SSL in Matillion? I am trying to access a client's API and need to disable SSL in order to access their API.
I am able to access via Postman and using cURL in command prompt. Due to some constraints on the client's side, we cannot obtain an SSL certificate.
Hi @James3, have you figured out the solution for this yet?
I'm running into the situation, were you ever able to figure out a solution?
