Error Reporting - Header Authorization
Is there any way to modify the HTTP header for the "Error Reporting" feature? I'm trying to integrate Matillion with Datadog, which requires an API key for authentication. But I only see a way to modify the message payload, not the header information. Thanks!
Hi @daniel.dixon​
No, there isn't. But I'd suggest that you raise this idea in the Ideas Portal.
Our team will definitely look into adding it to the product if the demand and interest exist. A recent example of how Community members have helped shape the product is in this month's release notes.
Cheers!
Chika
