Error Reporting Payload Examples
Hello All,
I'm testing the Error Reporting feature by sending a message into MS Teams. Anyone care to share an example of their payload? I feel I have the essentials, but maybe I might be missing something. Here's my example:
 "title": "Matillion Runtime Error in Job: ${job_name}",
 "text": "Job Name: ${job_name}
  Component Name: ${component_name}
  Component Message: ${component_message}
      Detailed Error: ${detailed_error}"
This was our basic payload when we started to use the feature:
"title": "Failed Matillion Job in Project ${project_name}",
"subtitle": "Job Name: ${job_name}",
"text": "
*Component Name:* ${component_name}
**Component Message:** ${component_message}
*Detailed Error:* ${detailed_error}
Nowadays we use a more sophisticated layout which produces the following output:
"@type": "MessageCard",
"@context": "http://schema.org/extensions",
"themeColor": "0076D7",
"summary": "Failed Matillion Job in Project ${project_name}",
"sections": [{
"activityTitle": "Failed Matillion Job in Project ${project_name}",
"activitySubtitle": "Job Name: ${job_name}",
"activityImage": "https://upload.wikimedia.org/wikipedia/commons/thumb/6/63/Green_bug.svg/200px-Green_bug.svg.png",
"facts": [{
"name": "Component Name",
"value": "${component_name}"
"name": "Component Message",
"value": "${component_message}"
"name": "Detailed Error",
"value": "${detailed_error}"
"markdown": false
Hi @Michael​ .
I've been trying ​to handle the error message using webhook post component refer to this topic.
In my case, I would like to post message to slack, not MS Teams.
This is my webhook payload templates below.
"text": "
*Error:* Failed Matillion Job at the project below.
*Project Name:* ${project_name}
*Job Name:* ${job_name}
*Component Message:* ${component_message}
Then, I put webhook post component on the canvas like this.
What I would like to do is that if the Sharding Retry component was failed, webhook post component will get error detail and post it to slack channel.
But when I run this job, variables were not substituted.
One thing that I tried was define environment variables, but the result was not changed.
I think I don’t need to define variables like ‘component_name’, ‘job_name’ and things like these because it has already defined by Matillion originally, but should I define again or do something??
Thank you.
Dear @Michael​
Thank you for your prompt reply.
​As you said, it was successful when I write like "{{component_name}}" on Manage Webhook Payloads template.
In addition, I understand that If I don't define template and use custom at property, I could write "${component_name}" and it was successful.
Thank you for your explanation and I hope it's gonna be useful for all Matillion user.
This is absolutely above and beyond anything I was doing. Thanks so much for this!!
I think the magic is to escape the variables correctly. For unknown reasons, Matillion apparently decided to design both the "Manage Error Reporting" and the "Webhook component in a different way.
My example works for the "Manage Error Reporting" feature. If you use the Webhook, try to escape variables as follows:
"value": "{{load_error}}"
You don't have to re-define environment variables.
Dear @Michael​
There is an additional problem about webhook component, so I'm glad if you know how to solve this problem,.
First, I could handle error report as I wrote previous post.
Then, I would like to define it as a Shared Jobs because I don't want to define on each job.
This is my webhook payloads template named error_report.json below.
"blocks": [
"type": "header",
"text": {
"type": "plain_text",
"text": ":warning: Matillion Runtime Error in Job: {{job_name}} :warning:"
"type": "divider",
"block_id": "divider1"
"type": "section",
"text": {
"type": "mrkdwn",
"text": "*Project group:* {{project_group_name}} \n *Project:* {{project_name}} \n *Job name:* {{job_name}} \n *Full error message:* \n {{detailed_error}}"
"type": "actions",
"elements": [
"type": "button",
"text": {
"text": "Open Project"
"url": "{{url}}"
Then, this is some orchestration in order to create Shared Jobs.
After I define it as a Shared Jobs, I use it on orchestration job like this.(Sharding Retry component is gonna be failure)
As a result, there is a notification to my slack channel, but ‘job_name’ is equal to shared job’s component name like this.
I could get 'detailed error' but I can't get 'job_name' , so if someone know how to get 'job_name'(not shared jobs component name), please let me know.
Thank you.
​Dear Michael
Thank you for your reply and explanation in detail.
Thanks to your advise, It was successful and this is what I wanted to do!!
I really appreciate it and hope it will useful for other Matillion user.
Thanks Michael!
What I am doing is to add variables to the Payload Template, like "job_name": "{{job_name}}" and then define the Payload Variable job_name as $(job_name).
I guess there is not easier way of doing this, right?
Hopefully Matillion sort this out at some point.
Yes, I guess that's currently the best way to go...
I think you can't use $[job_name} directly in the shared job as this variable will always point to the currently running job (which is the shared job in this case).
Try to add a public variable to the shared job and call it "my_job_name". Then, from the job where you have "Sharding Retry", assign "my_job_name" the value ${job_name}. This should pass the name of the outer job to the inner (shared) job.
