Hi. I see there is a Orchestration->Connectors->Load component for Jira Query. I am expecting to be able to find one for Wiki but can't find it. What is the best way to bring data into Snowflake from Atlassian.net/wiki using Matillion?
Hi.
I am expecting to be able to find one for Wiki but can’t find it.
What is the best way to bring data into Snowflake from Products | Atlassian using Matillion?
Hi @margaret.brown1590642696104​,
Your best bet is going to be to use the Altassian API. You can do this by using API Profiles or a Python script in Matillion. In this scenario, I would lean towards API Profiles in Matillion. The one thing that you will find with either solution is that you are going to need to know/learn about Altassian's API implementation. Authentication is usually an area that hangs people up with API's because not every company does API authentication the same. Hopefully this helps get you started.
Thank you very much Bryan...I appreciate your guidance.
