Hi! stage management for azure asks azure credentials unable to figure out what "Client ID" and "Security Key" is. Help appreciated!
Hi!
unable to figure out what “Client ID” and “Security Key” is.
Help appreciated !
Hey
Check if these steps helps you find the details, you may have access or need admin help:
  - Go to your Azure website: portal.azure.com
  - Click on "Azure Active Directory" in the menu.
  - Find and click on "App registrations."
  - Choose your app or create a new one.
  - Look for "Application (client) ID" – that's your Client ID.
  - Still in your app, click "Certificates & secrets."
  - Under "Client secrets," click "+ New client secret."
  - Give it a name and an expiry, then click "Add."
  - The new key that shows up is your Security Key.
You can also check matillion help page.
Thank you for the time and response!
I tried this before I post my issue here and noticed the azure credentials issue persists.
unfortunately I still am unable to load data from azure to snowflake through matillion.
