How can I check compatibility between Matillion ETL and SAP Netweaver Query?
I read documentation available documentation and I wasn't able to find anything about versions compatibility:
https://documentation.matillion.com/docs/2646366
I have Netweaver 7.01 and SAP 6.0x. Can I use Matillion ETL along with these versions? Are they compatible?
Thanks for your help.
Hi Ozkhar,
There's nothing in the Matillion docs about the supported versions, and I don't think there's any way to check it without simply launching a trial instance and testing the connectivity. But I believe Matillion ETL will connect to any SAP ECC version 6. It's a type 3 JDBC driver so it has another requirement the RFC SDK must be available.
JB
Ok, I will try this.
Thank you, @JB​
