I am facing issue , in adding data source in SAPNetweaverQuery component in Matillion tool
Hi All, I am facing issue in adding data source in SAPNetweaverQuery component in Matillion tool.
issue: SAP JCo library not found: verify the correct jar file is present.
can someone help with the same?
Hi @banerjeeaniruddh2​
Thanks again for your post, I assume you got past this section as per your latest post, I am will pop an answer to that one over shortly.
Thanks Joe
Thank you @JoeCommunityManager​
