How can I reset password of my ETL instance I configured.
I am using Matillion demo instance.
I dont recall it and want to reset it.
Please help in this regards
you should be able to see something in your Project Menu --> Change My Password.
Thanks for offering assistance, @AnudeepK
Hi @vipin.chopade, here is a document explaining how to reset passwords: https://documentation.matillion.com/docs/3383165
Chika
Thanks all for your reply however my question was different.
I have changed my admin password for the user ec2-user and not able to recall so couldn't login to Matillion ETL instance.
That's the reason want to reset it..until and unless you don't login to Matillion ETL instance you can't change the password.
Hi @vipin.chopade
The linked document outlines how to change that password via an SSH session with the instance: https://support.matillion.com/s/article/How-To-Reset-the-Password-for-the-EC2-User
I hope this helps but please let me know if there are any questions.
Cheers,
Chika
